ForgotPassword?
Sign Up
Search this Topic:
Forum Jump
Apr 9 14 5:39 AM
Apr 9 14 7:33 PM
Apr 10 14 8:50 PM
Apr 11 14 4:27 PM
Apr 11 14 7:15 PM
DavenSeattle wrote:To win the race with the Bridgestone you may have to add a spoiler to your bike to hold it down at high speed. Maybe use another license plate? I have a vintage 1976 (Bicentennial) IL plate.
Apr 13 14 8:51 AM
Apr 13 14 12:53 PM
thermiteguy wrote:IT LIVES!!!!! The little scooter is puttering around the neighborhood now! Many thanks and appreciation go to Nate, Mel, and all the knowledgeable guys at tech day! Thanks so much! Plus, I learned a number of things. Oh, and the problem? The cam chain sprocket was 90 degrees off. We flipped that around the right way, and she fired up in 2 or 3 kicks.
Apr 13 14 6:48 PM
Apr 14 14 12:18 PM
Apr 14 14 5:34 PM
Apr 14 14 6:50 PM
Apr 15 14 6:34 AM
thermiteguy wrote:Yep, ya found me Nate. I'm going to go take the side cover off. Take a look at the clutch and see what's going on. Now it's losing power in gear. It'll idle all day, even in gear. But give it some throttle, even just the slightest, and it stalls and dies. I'm glad you showed up, really helped me out. I hope those parts get you on the road!
Apr 15 14 7:02 AM
Apr 15 14 10:47 AM
Apr 15 14 2:59 PM
Apr 15 14 3:48 PM
Apr 15 14 4:32 PM
Go back and set the timing to the 'F' mark , that never needs changing .Just for fun , after you've checked for a vacuum leak , check the charge rate at the battery whilse it's running....Back firing out the carby can also be running too lean , IE : vacuum leaks and too small jets .-NateDeepBarney wrote:I got my jets in yesterday and installed them. And it'll fire first kick and idle, but when I rev it up it wants sputter and die, just off idle it does this. And it's developed a habit of back firing. No amount of adjusting the carb or timing at the points plate will solve this. When in gear it feels real weak like it doesn't have the power hardly to move itself. If anyones got an idea please feel free to advise me. I posted in more detail here: http://hondatrailcts.yuku.com/topic/7793#.U02r1KJTYcY
Apr 15 14 4:57 PM
Apr 15 14 5:58 PM
1980FLH80 wrote:DeepBarney, you just described a vacuum leak
Apr 15 14 6:17 PM
vwnate1 wrote: Go back and set the timing to the 'F' mark , that never needs changing . Just for fun , after you've checked for a vacuum leak , check the charge rate at the battery whilse it's running.... Back firing out the carby can also be running too lean , IE : vacuum leaks and too small jets . -Nate DeepBarney wrote:I got my jets in yesterday and installed them. And it'll fire first kick and idle, but when I rev it up it wants sputter and die, just off idle it does this. And it's developed a habit of back firing. No amount of adjusting the carb or timing at the points plate will solve this. When in gear it feels real weak like it doesn't have the power hardly to move itself. If anyones got an idea please feel free to advise me. I posted in more detail here: http://hondatrailcts.yuku.com/topic/7793#.U02r1KJTYcY
Share This
