ForgotPassword?
Sign Up
Search this Topic:
Forum Jump
Aug 5 13 3:43 AM
Aug 5 13 11:30 AM
vwnate1 wrote: ? Are you taking the time to clean the centrifuge each oil change ? .I feel your pain , it's difficult to get all the old SWARF & debis out of the sump . I've used gasoline , brake cleaner Etc. , Etc. all with good results *but*........This week , to - day in fact I plan to ride my '70 K2 back to El Monte where The Bke Pimp has a new bracket made up for my 1912 Maxwell Klaxon waiting ~ .The only thing that beats riding an old Tiddler around ton is riding it whilst tooting a vintage AHOOGAH ! horn .Yes , I'm another foolish old man who has as much fun a I can sueeze into each day .
Aug 5 13 9:28 PM
Aug 6 13 4:50 AM
Aug 6 13 9:04 AM
vwnate1 wrote: Have you replaced the rectifier yet ? .Until you do so , you'll have continual battery problems and off and on poor running because the battery is the voltage regulator in these fine Motos and once it's over 12 months old or has been allowed to go dead , it needs replacing .The water level in it too is critical ~ buy a small syringe and use it to keep the electrolyte levels right at the fill line and always use distilled water .'
Aug 6 13 9:40 AM
vwnate1 wrote:Have you replaced the rectifier yet ? .Until you do so , you'll have continual battery problems and off and on poor running because the battery is the voltage regulator in these fine Motos and once it's over 12 months old or has been allowed to go dead , it needs replacing .The water level in it too is critical ~ buy a small syringe and use it to keep the electrolyte levels right at the fill line and always use distilled water .'
Aug 6 13 10:13 AM
Neal at the theCTshop.com in Auburn Ca. If it works, Don't fix it
Aug 6 13 11:53 AM
You might be surprised how many don't get this and simply refuse to even give it a try .BTW : with original rectifiers , the battery is always going dead because they " leak " a tiny bit of current when the engiune is off .-Nate Russman wrote: +1, my experience has been that a good battery is what makes my 90 a one kick wonder, when the battery is weak, he gets hard to start and will begin to misfire at the top end.
Aug 6 13 5:28 PM
Aug 7 13 5:07 AM
Aug 9 13 11:33 AM
Aug 9 13 2:33 PM
thermiteguy wrote: I did not know that. Thanks for that info. I'm gonna add it into my notebook of full of notes for this bike. Sadly I spoke too soon. The bike still fires on first kick, but there is a dramatic lack of power (still no air filter, will probably get the uni-filter. I had a K&N, but couldn't get it to fit with the body unles I bend the sides of the filter). Before, with the high idle in neutral, it rocketed me up and down my block. Now it sputters along barely giving me anything. And it's not wanting to catch gears, but that's because the chain has no slack. I made ti too tight, so after dinner I will be going to adjust that rear wheel.
Aug 9 13 9:57 PM
russman wrote:thermiteguy wrote: I did not know that. Thanks for that info. I'm gonna add it into my notebook of full of notes for this bike. Sadly I spoke too soon. The bike still fires on first kick, but there is a dramatic lack of power (still no air filter, will probably get the uni-filter. I had a K&N, but couldn't get it to fit with the body unles I bend the sides of the filter). Before, with the high idle in neutral, it rocketed me up and down my block. Now it sputters along barely giving me anything. And it's not wanting to catch gears, but that's because the chain has no slack. I made ti too tight, so after dinner I will be going to adjust that rear wheel.When I first got my '69, I just couldn't get he carb quite right. Finally I decided to inspect the airfilter and found out that there wasn't one in the housing... just a hose to nowhere.I bought a filter and connector and put the system back to stock and the bike ran PUUURFECT. I think these bikes just run better when all the stock stuff is in place.
Aug 10 13 6:08 AM
Aug 10 13 8:02 AM
Aug 10 13 2:22 PM
Aug 10 13 4:12 PM
Aug 10 13 6:08 PM
Aug 10 13 8:10 PM
Aug 13 13 6:34 PM
Share This
