Help!! Put new battery and rectifier on my 77' CT90 and my headlight dims real low when I turn blinkers on or mash the brakes. Also, when I'm at idle, it will slow the engine and eventually die when I do blinkers or brakes. I ask this question earlier in a post, but it just seems a little to much from normal the way it's acting. Where do you hook the yellow and pink wire on the rectifier excactly anyway? I used a rectifier from Radio Shack model 276-1185. Thanks for any help,Scott.
