My 77' CT90 has started leaking gas from the overflow tube when I have the engine off and coincidentally has started cutting out when I accelerate from a stop. I am guessing a float problem, but I used a clear hose from the bottom port of the carb and turned the drain screw on and it rises to about midway on the carb where the screws hold the two halves together. Any suggestions? Thanks,Scott
