The previous owner of the Green Machine drilled through the kickstart lever and shaft when the spline became worn and wouldn't clamp.
Is it possible to use a dremel cutting disk to return some groove on the smoothed spline shaft? I really don't want to dig deep enough to replace the shaft.
