While removing old gasket material and getting ready to reinstall the top-end on my '74-K5, I found that there were two gaskets between the cylinder base and the cases. I bought a Vesrah gasket set from dratv and it came with only one base gasket. This bike has had the top-end done before, since there is an aftermarket piston in it.
What have you all out there found when tearing these down? Do I need two gaskets?
